Simple Question about Progressive Scans
Discussion in 'Blu-ray & DVD Players & Recorders' started by Galactus, Jan 9, 2004.
  1. Galactus
    Galactus
    Hi Guys!
    Am about to buy a new DVD player, and I did a little online research about "progressive-scan capabalities" before actually buying.
    Most sites said that if you dont have an HDTV (and I dont), progressive scan won't do much with regards to picture clarity.
    Is this true?
    I just have a 29" TV (Sharp), with the usual features and jacks (S-Video, Component and RCA). If so, then I'd rather settle for the relatively cheaper "non-progressive scan" DVD.
    Thanks in advance for the reply.
    ps - I've read several links on Progressive Scans, and they're too technical for me, so a layman's answer is appreciated
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Progressive Scan (PS) requires compatible equipment, i.e. if you TV is not PS capable (does not have a YUV input which supports PS) you will not benefit from a PS player.
    PS does not directly relate to HDTV, it's possible to use PS without HDTV, but benefits of PS might only be visible on larger screens.
    External De-interlacers/scalers (in combination with a e.g. projector) might achieve the same or better performance.
  3. Galactus
    Galactus
    Thanks for the reply, Reiner. Very clear and concise.
    However, pls indulge me with another question.
    What's a YUV input?
    Just checked the back and front jacks of my TV. All I have are 3 RCA jacks, an S-Video, 1 Component and 1 Composite jack.
  4. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    YUV inputs are component inputs. They will be coloured red, green & blue.
    This would would mean you would be able to connect the dvd to the tv with three component leads but as Reiner says, if the TV isnt prog scan compatable then you would only use the interlaced signal.
    I'd hazard a guess that your tv isnt prog scan compatable.
  5. Galactus
    Galactus
    Thanks for the reply, WeirdFish. I guess I'm better off with a non-PS DVD player
  6. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    I wouldnt lose sleep over missing out on something as the difference is subtle, even on my 6ft screen.
  7. Jayb
    Jayb
    Feb 6, 2003
    149
    19
    Nottingham
    I have a tosh 520 & 32zd26 TV, both can handle progressive scan for ntsc material, if I toggle between progressive scan on and off, even with my 32" TV the difference in picture quality is very noticable with region 1.
  8. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,765
    2
    In a secret location with Jennifer Lawrence
    +9,558
    Moved to DVD players.
    Greg
