Simple query re settings for my sub
PhilPR
I have had my sub away for the past 2 weeks being repaired, its an old CT Velodyne.
Back this afternoon and plugging it in but its been a while and settings have been changed during testing. Could some kind soul confirm a few things for me?
I have a subwoofer out from my Denon X2600H, does it matter which L/R input it goes into?
Internal x-over or direct toggle?
Phase, I plan to set to 180 as the SW is behind the seating area, opposite the amp/tv. Correct?
Power on/auto set to auto.
Low pass crossover, does this matter as presumably the amp will decide what to send?
Subwoofer volume, I got that one :D
Thanks in advance, just want to double check.
Phil
Conrad
No
Direct
I'd leave it on zero. Audyssey will set the phase to whatever integrates best with the mains.
Yup
This control should be bypassed if you set the sub to direct instead of internal x-over, but set it to max/120Hz anyway, just in case.
Upvote 0
PhilPR
Many thanks, also been reading the faq which I should have read first!
I read a lot before setting this up first time around several years ago, but the sw issue also occurred at the same time as a new amp so its a whole new ballgame now with settings to get to grips with.
Upvote 0
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
