Simple (?) Networking Question
Discussion in 'Networking & NAS' started by Rambles, Feb 20, 2005.
  1. Rambles
    Rambles
    Jul 14, 2004
    10,444
    167
    UK
    +2,152
    I currently have my media center pc connected to my main pc using a crossover cable ethernet to ethernet and internet connection sharing enabled. If I wanted to use a broadband router instead (to add a third pc) woud I have to 'un-cross' the existing ethernet cable??
    fanx
    :confused:
  2. Bubbauk
    Bubbauk
    Sep 27, 2004
    178
    Belfast
    +4
    lisag, yes you would, you need to use a straight through (patch) cable to be able to use a router, there are convertors to convert a patch to a crossover not sure if there are ones for the other way round, network cable is cheap anyway.
  3. Rambles
    Rambles
    Jul 14, 2004
    10,444
    167
    UK
    +2,152
    Thanks for the quick reply, I was hoping for a different answer, the cable is routed through my entire house and I am not re-doing that.... I had to borrow some crimpers to cross it over in the first place.... it took ages, very fiddly :suicide:
    Will have a look for an adptor, good idea
    :smashin:
  4. Werner
    Werner
    some broadband routers support auto mdi switching, so you can use any cable
  5. Rambles
    Rambles
    Jul 14, 2004
    10,444
    167
    UK
    +2,152
    Oh thanks, that sounds hopeful, will research that.
    Another thought - if I replaced my USB ADSL modem with a USB ADSL router could I leave the existing x-over cable connection as it is? Just add extra connections via the router?
  6. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,955
    Manchester, England
    +84
    All you need to do is buy a female to female UTP connector like this one: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=1795 and another short crossover cable. connect the cable extender to the existing x-over cable then plug the new short x-over into the other side. this will "uncross" the cable.
    I have this in my setup at home and it works fine.
    HTH
    owain
  7. MikeFish
    MikeFish
    All the modem/routers i have looked at recently have automatic cable detection. This means you can use your existing cable and the router will detect this and adjust accordingly.
  8. Rob100
    Rob100
    Nov 3, 2002
    3,485
    +227
    Yep have to agree. Just about all routers and switches I've used over the last 18 months or more have done this.
  9. Rambles
    Rambles
    Jul 14, 2004
    10,444
    167
    UK
    +2,152
    Thanks for the help guys
    :smashin:
