Simple it may be...not for me!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by wishy, Jan 22, 2008.
  1. wishy
    wishy
    Jan 23, 2005
    105
    19
    Boldon, Newcastle, England
    :lease:I have recently purchased a Humax LU26-TD1 LCD TV. What I need to know is how do you record DVD from a TV with freeview tuner built in?
    TV has AV1, AV2 but no RF loop through so how do I record.
    Do I connect AV1 on TV to scart in [DVD] to record digital channels and AV2 [TV] to scart out[DVD] to watch DVD's.
    TV manual says both AV1 and 2 output digital TV signal...stumped even though it is probably very simple, as am I!!!:rolleyes:
  2. marty2005
    marty2005
    Jul 22, 2005
    3,694
    Great Yarmouth
    +155
    I think scart 2 may be freeview out.
    scart dvd out ->tv scart 1 (might be labeled rgb) in.
    scart dvd in ->tv scart 2 out.
    Select AV1 on tv as this will be scart 1.
    On dvd recorder select AV1 and you shold see the freeview from the tv.
  3. wishy
    wishy
    Jan 23, 2005
    105
    19
    Thanks Marty2005, I think I tried this combo with no luck. Will try again tomorrow first thing.
    Both AV1 and AV2 are RGB as far as I know but AV2 outputs all signals from TV, ie digital TV analogue signal etc etc.
    http://www.humaxdigital.com/uk/pdf/LU26-TD1_leaflet.pdf Rather large 2.8mb .pdf so below is pasted info;
    Inputs / Outputs
    CI 1 CI
    SCART 2
    RGB SCART(among SCARTs) 2
    Composite In(V/L/R) 1
    S-Video 1 (Share w/ CVBS)
    Component(Y/Pb/Pr) 1
    HDMI 1
    S/PDIF 1 optical
    RS-232C 1
    Headphone Output 1
    I think the problem may be my cheapo Goodmans GDVD301R which i had problems recording from my Hummy PVR9200T in the past. Some have said here in AV Forums that this DVDR doesn't manage RGB in. This I find really strange if true...but if connecting the TV all singing all dancing AV2 to DVD scart in doesn't work then I'll be buying new recorder I guess.:suicide:
