jblandford
Hi there
Need a touch of advice
Take look at the attached - all sources in living room (upstairs) are scart through to b-tech switcher then on to Tosh TV and Yamaha AV amp
Existing hard cable connection from sky box (co-ax, bypassing old distribution amp (not sky eye compatible) to dining room downstairs (through loft which is beside living room but not possible to run cable apart from existing co-ax that can be utilised (was the origonal aerial lead)
Old amp in the loft has connections to all rooms via co-ax
I need to be able to use the sky box AND DVD player in all rooms and control them both
How do I do this via the existing co-ax (happy to replace the distribution amp) without any re-cabling
Oh - yes - I also run wireless networking!
Bit tough this one!
J
Bit tough this one!
J
