Simple HD70 lamp question
Discussion in 'Projectors, Screens & Video Processors' started by Tommy Angelo, May 5, 2007.
  1. Tommy Angelo
    Tommy Angelo
    I have received a spare HD70 lamp for my new projector and it looks unusual to me because there is no glass covering the front as there was on my AE500 lamps. Is this normal?
    I got a "free" lamp voucher that said I had to use it within 30 days of purchase and received the lamp with a receipt that said I had to report a problem within 2 days. So when I need to replace my lamp the warranty will be out of date. So I'll be a bit annoyed if it has a problem
  2. Delh68
    Delh68
    Dec 13, 2002
    1,057
    48
    +55
    If you got it from Sean, you could always PM him on here ~ also, isn't there any info about changing the lamp in the manual of the HD70, (diagrams, etc) that might help you out??
    I think a lot of lamp warranties are 30-90 days normally anyway, so they don't give you much time if you only use it a couple of hours a day, to discover a problem:eek:
    Delh68
  3. Delh68
    Delh68
    Dec 13, 2002
    1,057
    48
    +55
    Having said that about Sean, i can't seem to find his user id anymore ~ sorry:(
    Delh68
  4. Delh68
    Delh68
    Dec 13, 2002
    1,057
    48
    +55
    Right, i'm glad to say i've not gone totally mad, Sean's user id is thescoobydoc
    Hope this helps
    Delh68
  5. Tommy Angelo
    Tommy Angelo
    The projector and lamp voucher were from Sean but the lamp was directly from Optoma.
  6. AV Nik
    AV Nik
    Jul 11, 2006
    581
    46
    +100
    The Optoma Lamp Vouchers are redeemable at any time. You no longer have to claim within 30 days and the voucher lasts for as long as you keep the projctors receipt of purchase.
    The amount of time you have the lamp, before using it, is now irrelevant.
    If you have a problem when you install any Optoma replacement lamp, you have to report that problem within two days.
    If you have any problems or questions about any Optoma product, they are generally quite helpfull if you ask.
    Either that or ask one of us (accredited partners).
    Hope this helps.
