Hello all,
I have a problem that I would much appreciate some help with...
I've had a Toppy 5800 for a few years and I'm happy. However, I want to get programmes off it and onto my NAS so that I can view them from different tellies in the house. I also want to do some *very* basic editing on the files (basically top and tail them - lots of episodes of Peppa Pig for my kids that are about 18 minutes long but the program is actually 10 at most). I want the resulting files to be in a format and file wrapper that is standard but likely to be outdated in the near future. I want good quality but I'm not obsessed by it; we're talking about Peppa Pig here!
My editing requirements are very slim and I don't want any bloat-ware and I don't want highly geeky tools that look like an aeroplane cockpit. Consequently I'm more than happy with simple, intuitive freeware.
I've done a fair bit of research and I've so far done the following:
- Used Altair to copy the .rec files from Toppy to NAS, no problems so far
- Downloaded the free VLC Media Player that seems to get very positive reviews, is nice and simple to use and not at all bloated. I'm very happy with that and can play the .rec files no problem.
- To edit the files (top and tail, maybe cut adverts if I can be bothered) and get them in a more universally accepted format I've used Handbrake. I've tried both the 'classic' and the 'standard' presets, trying both FFmpeg and H.264 as encoders and tried .avi, .mp4 and .m4v as wrappers.
- The resultant files (FFmpeg wrapped in mp4 say) seem fine and play on the VLC Media Player no problem. So far, so good....
- A bit of research has shown that the best free editor, for simple, quick editing are perhaps either Avidemux or Virtualdub. I don't want to import a library of files, I don't want a myriad of features, I just want to open a file, trim it and save it. This basic trim ideally shouldn't need to decode recode either, just a minute or so a file to top, tail and save.
HOWEVER.... Neither Avidemux nor Virtualdub can open the files I've created with Handbrake. I've tried different encoders and wrappers and tried forcing the framerate to be fixed rather than 'same as source' but whatever options I try Avidemux just says "Cannot open file".
The thing is, the .mp4 file plays fine on VLC Media Player and I can open it another "free trial" editor (can't remember the name, sorry). However, this free trial editor wants to create a whole library of my files yadda yadda and all sorts of stuff. It's really bloaty, takes ages to start and isn't the quick and simple solution I want.
For the same reason I really, really don't want to go back to ProjectX, and have to demux the .rec file before combining it back to a .mp4 or .avi. This is way too techy and is too many steps. I'm really happy with Handbrake which has just converted the .rec file to a .mp4 file in ONE CLICK and the resulting file plays fine on VLC Media Player. BUT, the question is, why can't Avidemux open it?
So what I really want to know is what settings do I need on Handbrake in order to create a file that Avidemux can handle?
If it turns out this is impossible, which seems bizarre, then I would appreciate the suggestion of an alternative pair of tools to convert to .mp4 and to edit. The key is though, the conversion to .mp4 must be a one click solution that doesn't require me to do things like pick which audio track I want to keep.
All advice most gratefully received.
Regards,
Hugo Read.
Regards,
Hugo Read.
