simple control system needed please help
Discussion in 'Home Cinema Control & Remote Controls' started by jon114, Jun 10, 2005.
  1. jon114
    jon114
    i work within the av industry and am starting work for myself doing basic projector installs for pubs etc. i am looking for a basic control system to control a projector as well as audio. i need it to be very user friendly and low cost,i have looked at crestron and amx and they are over complicated for what i need
    can anyone recommend anything,
    thanks
  2. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    You could have a look at a pronto / intelligent remote type device that will allow you to set up marcos to trigger all your devices in a specific order from a single button press.
    If you want a AV and IR routing systems you could also look at the AV over Cat5e systems such as the nexus from AV Nex (www.avnex.co.uk)
    Chris
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    better off looking at commercial systems then, domestic control and commercial differ a lot commecial kit has more interface choice but for controlling a screen, trigger it off the PJ and have an AMP with buttoins and knobbs behind the bar, thats how 99% of pubs i go to work.......
  4. jon114
    jon114
    i presume when you say "pj" you mean the projector remote control??
