Hi mate,
The normal sky codes work but you have to turn them on in the sky Q box settings.
In the remote control set up section just choose the easy grip remote control and that will make the original sky infrared codes function the sky Q box.
Hi Gazpoz
Did you manage to get the SY Q set up on the Simple Control App.
Also does it provide you with program information in the same way it does with TiVo and Direct TV.
Thanks V
