simple answer please what amp do i need to get true hd audio from a ps3
Discussion in 'AV Receivers & Amplifiers' started by toddy28, Sep 9, 2007.
  1. toddy28
    toddy28
    Aug 20, 2007
    3,650
    +686
    got the duo accustic 77a and now need to buy an amp what do i need to get true hd sound from my ps3 or is this not possible looking at the onkyo 605 or denon 1908 what do you recommend
  2. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    You need to be looking at the onkyo 605, bottom line is without analogue outs on the PS3 you need an amp that can do LPCM over HDMI
  3. toddy28
    toddy28
    Aug 20, 2007
    3,650
    +686
    will the denon do that as i have a 1930 dvd and would like them to match
  4. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    I don't believe so, you've got to be pretty careful with all this with regards amps and make sure it does Audio over HDMI, a lot of amps will do HDMI switching but they won't carry the high definition audio formats a lot of people have been caught out by this. It's the main reason that onkyo have been selling so many of the Onkyo 605's because it's an affordable receiver with HDMI 1.3 and can do the HD Audio over HDMI. I'm no expert but if you want denon you are probably looking at the denon 3808
  5. toddy28
    toddy28
    Aug 20, 2007
    3,650
    +686
    thanks but i have more time to pick an amp now as i have just got an email from duo accustics my speakers are out of stock and the boat from china arrives in 3 weeks :(
  6. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
    In the 'old' range the Denon 2307 and upwards would handle LPCM over HDMI. I'm not sure what the equivalent numbers are for the this years Denons.
  7. Dann'sTheMan
    Dann'sTheMan
    Nov 1, 2006
    379
    Berkshire
    +55
    Do check out the 3200ES receiver and the models above from Sony. Mine works and sounds great with my PS3, :smashin:
    Big smiles,
    Andy.
  8. barnclos
    barnclos
    Mar 11, 2003
    +10
    I just read somewhere else (I am not sure about the rules for mentioning other sites, so 'no names, no pack drill') that 'The AVR-1908, on the other hand, offers true HDMI switching with audio,' - I don't know if this means LPCM audio, maybe sp_harris or dazza74 would know.
    For info, the 'on the other hand' was in comparison to the 1508 and 1708 which only did video switching.
    The 1908 will be a better match for your 1930 than a non-Denon amp, but the new (xx08) amps have significantly different styling to last years models - they've gone all wavy.
  9. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
  10. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    just go to Denons website, pick a machine, check out the detailed specs, if its got a dot for LPCM then it will handle content from the PS3 if the PS3 decodes first to PCM then outputs via HDMI....
