Simple Amp Advice Required
Discussion in 'AV Receivers & Amplifiers' started by U187146, May 29, 2005.
  1. U187146
    U187146
    May 7, 2005
    62
    A nice easy one for Sunday afternoon.
    Looking to power the following in-ceiling speakers.
    Room 1 - Sonance Virtuoso 80w 8 ohm x 2
    Room 2 - Sonance Symphony 100w (single stereo)
    Use will primarily be for listening to music, sourced from a media center PC with digital music files, using a decent soundcard. I may also take an LCD TV through it also, but nothing else.
    What Amps would you recommend. Not looking to spend a huge amount, though would really need indepent switchable channels for the two rooms and ideally remote control.
    Thanks.
  2. sholao
    sholao
    How do you intend feeding the amps if the music is coming from the same media PC.
    My point being that the amps would probably be in the same room as the speakers, and you would need a tablet pc or some kind of PDA to select the source and control the AMP. You might need a programmable remote like a Pronto.
    The amp can then be any remote capable one that can power the speakers and fit your budget.
