SIMpad touch-screen broken - help please!
Discussion in 'Home Cinema Control & Remote Controls' started by SpiceBoy, Apr 22, 2005.
  1. SpiceBoy
    SpiceBoy
    Nov 19, 2004
    Hi all,
    Can anybody help here?
    The touch-screen on my SIMpad has broken. It still displays fine but doesn't respond to the stylus, my finger or anything! I have tried both soft and hard reset, but when it asks me to calibrate the screen it doesn't respond when I touch the screen. The rest of the system is fine and I can see the device from my PC.
    Is the display broken? Can I geta spare part from anywhere? Is there anything I can check inside the casing?
    Thanks in advance for any help,
    Robin
  2. BestGear
    BestGear
    Oct 22, 2003
    1,258
    +45
    ...dont know if you have sorted your problem, but I found that there are two capacitors that can cause this.
    Do a google for linux, capacitor and simpad.. you will hopefully find the article!
    DJ
