Simpad problem Help please
Discussion in 'Home Cinema Control & Remote Controls' started by raydundas@bluey, Dec 30, 2004.
  1. raydundas@bluey
    raydundas@bluey
    I received an SLC model of the simpad today as I was told they were slightly better than the sl4, but it seems faulty. When I try to reansfer any file or programme with Activesync, it crashes the simpad and it needs reset. it also does not show same amount of memory as my SL4. Should it not have the same memory. I have even put on latest bootloader and upgraded to the same upto date O.S. 4.1 as my other simpad, but it is no better. Any suggestions ?
  2. mikeyavman
    mikeyavman
    Got another pc to try the sync software on? I thought the sl4 had more memory though?
  3. raydundas@bluey
    raydundas@bluey
    Its not the sync software. I did once manage to get a picture over to it and once got Remote control II over to it. With each, when I tried to use them on the simpad, it hung and needed reset
  4. mikeyavman
    mikeyavman
    and youve done all the fake dll stuff? or does RC2 not need that? I had such fun and games getting net remote working but it does now.
  5. raydundas@bluey
    raydundas@bluey
    Luckily remote control II does not need that done. The attraction I can see for netremote is it looks from the screenshots as if it supports transparent Gifs, which remote control II does not yet. it apparently will in a future update. I have to say though, that Frank at wincesoft has been so helpfull with the programme and the simpad that I am sticking with his programme. happy I broke the habit of a lifetime and bought a full legit copy of a great bit of softwaee :~))
  6. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,007
    Southampton
    +233
    Ray - Which cable method are you using to sync the Simpad with - USB or Serial?
  7. raydundas@bluey
    raydundas@bluey
    Serial. Seems sorted now. Had to do the drastic step and take the small round clip off the back and hold down button for 60 secs, then wait about 10 minutes and now I a have managed to load in remote control II and run it and the memory is now reading correctly, the same as my SL4. Thank you to all that helped.
    Ray
  8. mikeyavman
    mikeyavman
    Cool, we need to start a new simpad thread for config stuff.. Im using netremote purely for its ability to control my global cache.
  9. mikeyavman
    mikeyavman
    Ray, what is the battery like on your simpad? mine isnt lasting that long and today I had a shock to find that the battery had gone dead overnight and the simpad had been wiped of all my data and settings..
  10. raydundas@bluey
    raydundas@bluey
    I have not had that problem with the one I got from the muppet on Ebay. Not tested battery life on the SLC I have yet. Will use the battery button in RCII, to keep an eye on it though.
  11. mikeyavman
    mikeyavman
    can I ask where you got your slc? I cant believe its supposed to wipe the memory if the main battery dies..
  12. raydundas@bluey
    raydundas@bluey
    Also on Ebay from Portugal. I do not think it can save to its Rom, so if it dies completely you would loose everything, so the battery situation would be a big problem.
  13. raydundas@bluey
    raydundas@bluey
    Incidentaly, on my sl4, a soft reset does not delete installed programmes, but on the sl4 it does, wierd
  14. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,007
    Southampton
    +233
    I'm a little confused by your last post Ray - do you mean between the SLC & SL4?
  15. raydundas@bluey
    raydundas@bluey
    yes, sorry the SLC has the more extreme soft reset. It is true though that the screen on the SLC is better and response to screen taps is also improved
  16. mikeyavman
    mikeyavman
    Think Im going to go the XP tablet route. Put my simpad up for sale.
  17. raydundas@bluey
    raydundas@bluey
    How long is the battery lasting. I have just put the battery and memory monitor buttons on Remote Controll II so I can monitor it more closely and not get caught out. Is it an SL4 or SLC you have ? I was thinking myself that when simpad gives up the ghost, I would go for a tablet pC, though I think they are a lot heavier and a bit too big for a remote I think, but I do like the remote control II software and it does not work under XP as far as I know.
  18. mikeyavman
    mikeyavman
    Its lasting about 5-7hrs in fairness, I just wasnt expecting it to loose setting with a drained battery.. appears to be a feature and means you need to charge the pad once a week. Its an sl4.
  19. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,007
    Southampton
    +233
    TBH - I think this is the one area of weakness regarding the Simpad - I lost track of the days over the xmas break,and in turn lost all my software due to battery drain,due in part to it being used more,and not recharging it as required as a result.
    I left the house with the battery status on my RCII software power tab at 20% & came back the following day,thinking I'll charge it up .... but that was to late,as the battery has completely discharged..Although I backed everything up on a laptop,it was a pain in the ar$e to have to reinstall everything. :rolleyes:
  20. mikeyavman
    mikeyavman
    Wonder if you could hack the rom image to include remote software and the ccfs.. then it wouldnt matter so much.
    If I could find a dock id stick with the simpad though.
  21. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,007
    Southampton
    +233
    Likewise,although I fear that a dock for the Simpad is indeed a rare beast.
  22. mikeyavman
    mikeyavman
    Ive just put RC2 on it.. it appears much faster than netremote.. any idea if it supports global caches?
  23. raydundas@bluey
    raydundas@bluey
    RCII definately the muts nuts and ig you email frank at wince soft it is the best customer support I have ever experienced. He has already agreed to put in a small change in a future upgrade, on my suggestion. I was well chuffed
  24. mikeyavman
    mikeyavman
  25. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,007
    Southampton
    +233
    Ray - Sorry for being nosey,but what was the change that you asked Frank to put in?
  26. raydundas@bluey
    raydundas@bluey
    A selection box for new buttons, to switch between global and individual button, as sometimes when making a few new buttons, if you do not add them correctly, when you go to add the second button, it also changes the first.
  27. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,007
    Southampton
    +233
    Just updated to ver 1.11 - this program just gets better!
  28. mikeyavman
    mikeyavman
    sadly confirmed as no global cache support yet
