Similar Systems To Yamaha Av63
Discussion in 'Home Cinema Buying & Building' started by alfie_64, Feb 2, 2009.
  1. alfie_64
    alfie_64
    Oct 31, 2008
    I was pretty much set on buying a Yamaha Av63 as it best suited my situation for plugging into my xbox 360, computer and television, however they don't seam to be in stock anywhere so are apparently discontinued. Anyone got any ideas for similar systems?
    Any advice would be very appreciated.
    Thanks Alfie
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    yeh, look for the Yamaha AV63+.
    its the new model.
  3. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    The htddwg800 is also quite similar in spec and style to the av63+, you might like that too.
