Hi, am awaiting delivery of a D30H to replace my HT200DM - and just last week I asked the guys at projectorcentral.com to update their "projection-calculator".
Just stick the required dimensions in (metric or imperial) and "Robert's your Father's brother" as they say....
The widest image you will acheive from 11 ft with the Domino 30H is 73.3 inches wide, not diagonal. If your screen has a diagonal of 92" then its a 45" x 80" if it's
a 16:9 AR screen.
You would need a throw of 12 ft to fill a screen of that width.
Allow a foot from the back wall for the depth of the projector as the throws are worked out from the focal plane of the front of the lens. So you would need a room at least 13 ft deep to fill a 92" diagonal 16:9 screen.
