Sim2ht200
Discussion in 'Projectors, Screens & Video Processors' started by cobs, Jul 15, 2004.
  1. cobs
    cobs
    Hi guys, i have a sim2 ht 200 its only has 1400 hrs on the clock it came on for five mins then shut off the fuse is ok but it has no power would this be a lamp problem or something else thanks cobs :confused:
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Cobs,
    I did a reply to this thread you posted in the Sim2 Forum.
    I said to check both the power cable fuse as well as the projector fuse.
    It could well be a lamp problem.
    Depending on where you live I could check it out for you.
    Jeff :rtfm:
