sim2ht200 powerboard
Discussion in 'Projectors, Screens & Video Processors' started by cobs, Jul 25, 2004.
  1. cobs
    cobs
    HI guys can someone help me i have a sim2ht200 and the power boards have gone down all i get from sim2 is that ill have to send it back to them for them to fix it. but as i have it all apart now and if i can get hold of the power boards i can fit them myself so can someone tell me where i can get them from and the price thanks colin
  2. stevelup
    stevelup
    Aug 13, 2002
    6,560
    Swindon
    +1,111
    If SIM2 do a component level repair on your power board, it will almost certainly be cheaper than buying a complete replacement board.
    Also, the work will be guaranteed.
    I'd recommend posting in the dedicated Sim2 Forum, or search for forum member AD Roser.
    Steve
