Sim2 - Rtx55-h Grand Cinema Dlp Projection Tv
Discussion in 'Projectors, Screens & Video Processors' started by MJeeves, Aug 2, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Hello,
    Doe any one have any opinions on the SIM2 - RTX55-H GRAND CINEMA DLP PROJECTION TV? Is there any reviews out there? Does anyone actually own one? Would this be a better buy than a plasma (i.e. Pioneer 50"?). How would they compare in terms of picture, reliability and flexibility?
    Any info would be appreciated!
  2. simoncope
    simoncope
    I don't own one personally, but the company I work for has one on demonstration in their Beaconsfield showroom. Personally I would have one over a plasma screen any day - vastly superior picture. Of course, you get the usual RP issue of off-axis viewing (or lack of it), but it's not that bad.
    Obviously RP monitors are not as flexible as plasma screens in terms of mounting - you'd struggle to stick an RTX55 on the wall for example. And it is a bit unfortunate that there is nowhere convenient to place a centre speaker - it would have to go above the monitor on the wall.
    Reliablilty - not sure to be honest. One thing you won't get with the Sim2 is screen burn, as it a DLP device.
