Sim2 Introduce DVI to VGA Converter
Discussion in 'Projectors, Screens & Video Processors' started by RTFM, Mar 30, 2005.
  1. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    I have just taken delivery of DVI to VGA converter which is HDCP compliant.
    This will be a very useful device for users of projectors that do not have a digital input or have a digital input that is not HDCP compliant.
    Jeff :rtfm:
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I'm sure that must be in breach of some license, given what scaler makers like Lumagen have said about their equipment having to disable analog outputs when processing HDCP-crippled inputs.
    Are you sure there are no caveats about this in terms of resolution supported?
  3. Ahmadof
    Ahmadof
    Hi there, that sounds perfect (although is it too good to be true?). Where can I get hold of it?
  4. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    How much is it and do you have them in stock Jeff?
  5. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    And,will it improve me piccy on the 200DM?
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Hi Phil,
    The converter is only going to be of use if you have digital signals, ie. HDMI or DVI that you wish to feed your Sim2 HT200DM.
    The cost is £295 inc VAT and we do have them in stock.
    Regards
    Jeff
  7. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    will it improve the picture at all on my 200dm though?I have a panny s97 at the the mo,or what sort of deal you do me with the ex dem domino 20 you have?
  8. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Phil, the converter is just that, a converter. It won't improve the picture quality on your existing sources but will allow you to feed signals such as HDMI or DVI to your projector even if these sources are HDCP compliant.
    The Domino 20 would be a profound upgrade on your 200DM in all areas, ie. true wide screen 16:9 chip, higher res chip (1024x576 as opposed to 800x600 or 848x480), 12 degree mirrors giving much higher contrast (2000 to 1 as opposed to 600 to 1 ), built in Faroudja de-interlacing, much quieter...........
    Jeff
  9. adomingos
    adomingos
    Hi Jeff,
    Would connecting through this converter break the full digital chain ( hdmi/dvi - hdmi/dvi)?
    How would the image benefit through the use of this convertor to feed the PJ? Let's supose the DVD player is the Denon 2910 and the PJ the Sim Domino 20...
    How would this image be compared with the component progressive output of the DVD player?
    Consider all cables are high quality... by the way what are the max size advisable for DVI and for the VGA cables?
    Any other advantages of using the converter?
    If anybody besides Jeff want to answer you are very welcome :smashin:
  10. godzilla
    godzilla
    Oct 10, 2002
    661
    Lightwater
    +14
    So is this a way to get a hi def picture to my HT300 from say, the new Sky hi def box or a future hd-dvd player?
  11. adomingos
    adomingos
    Ok guys, regarding my own first question, of course it breaks the digital chain, VGA was always analog! :blush:
    However what I really wanted to know was some kind of comparison between the full digital chain vs. the use of this converter.
    Common guys, wake up! :clap:
    At least an opinion :lease:
    It sure is godzilla! :smashin:
  12. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Is this just the Korean box again?
