Sim2 HT300 Link Software
Discussion in 'Projectors, Screens & Video Processors' started by VUDSM, Jun 30, 2005.
  1. VUDSM
    VUDSM
    Does anyone know the latest software version for the HT300 Link (not the E version)?
    I'm currently running 2.37.04(L).
    Thanks,
    Derek
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Hi Derek
    Hope you're keeping well.
    The latest s/w for your 300 Link is 2.45.04
    Send me an email and I will send it to you by return
    [email protected]
    Regards
    Jeff
  3. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Hi Derek,
    I had your email in my address book so the s/w is on its way. Let me know how you get on.
    Jeff
  4. VUDSM
    VUDSM
    Hi Jeff,
    I've just received the new software from you. Thanks very much for that. I'll load it into my PJ tomorrow (it's after 11.00pm here now) and see if it fixes the problem.
    I'll give you an update one way or the other.
    Regards,
    Derek
    PS. Do you have the latest software for the Sim2 Domino 20H. One of my friends has one.
  5. VUDSM
    VUDSM
    Hi Jeff,
    I loaded the new software into my Sim2 HT300 Link. Although the new software loaded without a hitch, it didn't fix the problem with PAL discs and 720P resolution. I borrowed another HDMI DVD player (no name Chinese player) from one of my friends. I hooked it up to the Sim2 and tried a PAL disc at 720P. It played fine. So it seems that the Pioneer S969AVi may be the problem (even though it plays PAL discs at 720P on my Plasma ok via HDMI!). I think this is going to be one of those things that may be difficult to track down.
    Thanks again for your help.
    Regards,
    Derek
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    I will check on Monday with Sim2 as I think the latest s/w is 2.46.12 which was loaded in a Domino 30H that came yesterday.
    Jeff
