sim2-HT200--problem with progressive scan
A
agost
:lease: I've recently bought a denon 3910 to use with my HT 200
but when I set it to output p.scan my Sim keeps coming up with
"no signal" no matter what I do. The only way I can get a picture
is to change the setting on the denon to interlaced. The picture
looks fine but I am still confused as my previous Pioneer 737
would output p.scan on Nstc without problems
Any help would be v. much appreciated
Timmy C
This may seem obvious but are you selecting the correct input number on the Sim2 as they are different for interlaced and progressive? As far as I remember from my HT200 I had to select input 6 for prog. scan from my Denon 2900. Hope this helps!
A
agost
Thanks Timmy,
I did select input 6 on the HT 200 but still no picture-in fact there was
a black screen with intermittent lines . I'm wondering if theres something
wrong with the denon.By the way,what is the function of the Sim's own
de-interlacer?
Thanks again
Timmy C
The only other thing I can suggest is you try pressing the 'auto' button (green button on the bottom of the Sim2 remote) while your looking at the black screen you mention. I doubt it will solve anything but it's worth a try.
I dare say Jeff or Alan will post a more helpfull reply when they read this if it's a known problem. Otherwise see if you can borrow another 3910 and see what happens.
AD Roser
The HT200 was released before 576p 50Hz was developed - you shouldn't have any problems with 480p 60hz.
Please check as to which software version you have - the last release is 1.21 which should fix the problem. If you have this already then there may be a fault with the unit.
A
agost
Thanks Alan,
your suggestion sounds eminently logical-I will look into it.I am considering
a new domino 30h or 300e to fully utilise the denon's hdmi capabilities;
what level of superioty does the 300e hold over the domino? I have seen
the infocus pj's ,which although good are more like watching a big TV rather
than the SIM'S more involving beautiful images-I guess this is what people
mean by "more cinematic".Ultimately I believe we should all remember the
real reason we spend so much money-ie to enjoy movies even more .
So relax and enjoy !
Thankyou again for everyone's help and comments
AD Roser
The main difference between D30 & HT300E is that the 300E has DC3 and improved light engine to give a higher contrast.
As you have quite rightly identified, the superior optical performance gives clear, sharp "film-like" images over the other brand.
Trending threads
