SIM2 Domino 20
Discussion in 'Projectors, Screens & Video Processors' started by Oliveira, May 19, 2004.
  1. Oliveira
    Oliveira
    Hi guys,
    I´m considering upgrading my Sony HS10 for a Domino 20.
    Last week my dealer let me bring a Domino home for a trial with my Denon 2900 (component conection with progressive scan). The quality of the image was far better, but i´ve a few questions:
    - I´ve notice a bit of image noise (not present with the sony) in light color images (Like sky or snow) even in DVDs with great image like "Charlie Angels - SuperBit", Starwars - Episode II or Seabiscuit.
    - I´ve set the Domino in "anomorphic", i tried "pixel to pixel" but the image appears in 4:3 and kinda small :confused:
    I wonder if there is something i could do about this to improve the overall quality.
    Thanks.
    Pedro
  2. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    the image goes small as its matching the output of the dvd player with no scaling, the pixel X pixel option works best when fed with a PC, in your case 1024X576. which is i think the same as the domino 20s native res.
    as for pic noise make sure no noise reduction systems are active, i would also mention that with improved definition , disc encoding errors do become more noticable, and can look like pic noise when it is in fact compression errors etc.
    a bit off tweeking will probaly sort it.
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,405
    UK.
    +2,904
    Have you set the white and black levels using Avia or Video Essentials? If you have the brightness set too high, this can reveal lots of mpg noise etc. Using the correct gamma can make a lot of diference too. IIRC, there's a 'movie' gamma setting. RTFM should be able to point you in the right direction there though.
    Gary.
  4. Oliveira
    Oliveira
    Thanks for the replies.
    I bought Digital Video essentials and :) ...great.
    Thanks again!!!
    Pedro
