Sim2 Domino 20 - Will it do the job ?
Discussion in 'Projectors, Screens & Video Processors' started by Gaucho, May 24, 2005.
  1. Gaucho
    Gaucho
    My brother is looking to put a projector into a new extension. The main problem is that the throw from unit to screen is liable to be around 8.5 metres. In addition, the projector will be offset from the screen by around 20 deg.
    Don't know much about projectors. A local dealer has recommended the Sim2 Domino 20 (note sure if its 'H' version or not).
    I guess my questions are: -
    1) Will it work over that distance and what size/quality picture are we likely to get.
    2) Does this device have both types of keystone correction
    3) Would we need an additional long throw lens
    Hope someone can help
  2. Timmy C
    Timmy C
    Oct 10, 2003
    5,178
    +398
    You would be better off moving this down to the Sim2 forum. There will be someone to answer your question in detail there.
