Kshakeel
Hi, Im hoping if anyone can offer some assistance.
I have a lumis host and have installed the projector in a motorised lift recessed into the ceiling. However I got the throw calculation wrong and the now the picture is too small on the screen. The projector is about 4.8m from the screen and I need an image of 3.3m in width.
My current lens wont zoom in that far so the only alternative is to change the lens to a T1. I can’t move the projector as that would work out far too expensive now.
So my question is, do all sim2 c3x projector lines use the same kind of lens? Will a C3X lite T1 lens fit into my lumis host? Or does it have to be a particular type of T1.
Im also finding it difficult to source the lens. So any help in finding one would be greatly appreciated.
Thanks I’m advance.
Thanks I’m advance.
