Sim2 & Avia
Discussion in 'Projectors, Screens & Video Processors' started by JBT, Mar 8, 2002.
  1. JBT
    JBT
    I have a Sim2 HT200DM with a quadscan elite (set up myself as I live in the wilds far from any dealer) with a Cyrus DVD player. I find the picture excellant subjectively but decided after lurking for some time as a reader of this forum to take Gordon's advice and set up using Avia.
    I find that I cannot get the black levels set as the image will not at any setting distinguish the moving black columns which seem to be required for this paerticular routine.
    I have a relatively high gain glass beaded screen (da-lite), is this the problem and would a grey screen material such as da-lite's da-mat make a significant differance.
    Hope you can help
    JBT::confused:
  2. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    I've used Avia with a Sim2 200DM and found that on my Denon DVD-2800 on standard setting I was unable to show the moving black bars.
    The trick is to adjust the brightness and contrast on the video settings of your player. I did this with Contrast/Brightness at 50% on the projector. Seems to work for me.
    Regards,
    Ian Guinan
  3. music man
    music man
    Could you please tell me where you obtained the avia disc as i wish to purchase one to set up my projecter.
    Thanks in advance.
  4. JBT
    JBT
    I got my copy of Avia from Amazon.com (the US not the UK ) web site.
    JBT
