Sim2 300xtra and psm192
Discussion in 'Projectors, Screens & Video Processors' started by jeff sluijter, Aug 6, 2005.
  1. jeff sluijter
    jeff sluijter
    I am since short the happy owner of a 300xtra and tag 32flr with psm192 on board. I am relatively new to the a/v scene and simply "thrilled".
    Cannot experiment too much with cables and so on, so was wondering about your experiences. What gives the "best" picture:
    - the scaler of the Sim or the PSM192? What kind of Faroudja is in the Sim btw?
    - if PSM: component cable (via BNC) or the dvi connections?
    I was trying to play a cd on the tag, but no sound. I know that the player doesn't have a dac, but thought this was in my receiver (Sony 940). How comes? If not, wortwhile to go for a av32?
  2. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    it is a case of trial and error. but for my part i avoid the processing of the projector as i have found for most progressive souces(dvd) i tend to get a better picture from there processing as long as it is half decent.
    The Sim2 has the fl2310 chip
    Here is an example with the 300xtra-HDMI using the panasonic S97 set at 720p (so doing all the processing with its onboard faroudja fl2310 chip).
    even a cheap dvd player can create a very very good piture
  3. jeff sluijter
    jeff sluijter
    Thanks for the reply.
    I have been experimenting a little bit, but much to my suprise the picture appears better when I use the projectors board than the PSM192. With the PSM, I have - if you watch carefully - vertical lines in large even coloured parts, such as a wall.
    I know that it would normally be different. Any idea how this can be?
    I have connected it to the SIM via component BNC. Videos used were American NTSC ones.
  4. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Could just be old processing in the psm 192, giving what sounds like banding.
    If the projectors chipset is giving a better pic then go with that, better can be had but as usual at a price. but keep tinkering and remember to calibrate your brightness and contrast just right as this can make a real leap in picture performance when done right.
