sim2 200DM no power
Discussion in 'Projectors, Screens & Video Processors' started by cobs, Jul 13, 2004.
  1. cobs
    cobs
    Hi guys, i have a sim2 200dm its only has 1400 hrs on the clock it came on for five mins then shut off the fuse is ok but it has no power would this be a lamp problem or something else thanks cobs
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    cobs,
    It could well be the lamp.
    I would try another lamp in the first instance to see if that cures the problem.
    When you say you checked the fuse, did you check both the fuse in the mains lead and the one in the projector ?
    Jeff
