redmax
Established Member
I 've owned my PJ for about six weeks and have now finally finished building my first HTCP.
The finishing touch was when i took delivery of my HDMI cable which gives me a stunning image at 1280x720 @ 60Hz
Whilst I realise that the following query is slightly weighted toward HTCP I have posted here because I need to hear from other Domino owners about their experience.
My questions are:
1. I use an Asus A8 csm mobo with on board Nvidia 6150 GPU. When I connected via 15 pin RGB cable i was able to select 60Hz for NTSC and 75Hz for Pal.
Since switching to HDMI i can only selct 50Hz or 60Hz. I know some people just leave all sources at 60Hz as a happy medium but why am I limited to 50 or 60Hz. Is this just the limitations of HDMI or the GPU?
The GPU was able to output 75Hz via RGB so why not HDMI?
If I check the "monitor" tab in display properties in XP it states that I am outputting to a "plug and play monitor". Is this the problem? Obviously there are no drivers for the PJ so how can I inform windows that my monitor is capable of displaying 1280x720 @75Hz. (I presume the pj can display this)
I would appreciate any comments from fellow Domino owners and what refresh rates they use and how they get there.
2. I am also trying to get the RGB from my Sky+ to the PJ.
I have been informed that i can purchase a Scart breakout to RGBs.
I can see there is a fourth input on the PJ above the RGB inputs for a sync cable but will this accept the 15Khz signal from a cable like this one http://www.tvcables.co.uk/cgi-bin/tvcables/PGV7405.html?id=GCZRQm5E
Obviously i don't want to waste £50.00 on a cable that may not work.
Once agin I would appreciate any knowledge or experience from Domino owners if they have been successful at getting RGB signal from their Sky+ to the PJ.
I know there is a convertor available to convert from RGB to component but I would prefer minimal hardware between source and PJ if possible.
Thanks for looking anyway.
My questions are:
