T
tim_kay
The 4 pin adapter on the case that plugs into the same power as the floppy, and the 2 pin power switch plugging into the 2 pin case, as well as the usb causes the system to crash, or makes the pc powerless (will not turn on).
If you take the 4 pin cable out for the VFD screen it works fine.
This is using the following setup
LN12036 331 Intel Celeron-D Socket LGA-775 (2.66 Ghz, 256k Cache, 533mhz 90nm) Retail + 3 Years Warranty £44.26 £52.01
LN12252 Asrock 775Twins-HDTV S775 ATI Xpress200 DDR667/400 PCI-E ATI X300 VGA SATA Lan USB2 6Ch Audio £37.00 £43.48
LN9871 512Mb DDR2 PC2-4200 533MHz non-ECC 240 DIMM unbuffered CL4 Retail £18.89 £44.39
LN11833 NEC ND-4550A Silver 16x16 DVD±RW Dual Layer DVD-Writer OEM UK £25.58 £30.06
LN10235 Hauppauge WinTV-Nova-T MCE Freeview receiver PCI OEM (1070/DVB3P) £44.00 £51.70
LN11643 SilverStone "LASCALA" LC16S-M + VFD IR (Silver) Aluminum Front & SECC Body Desktop case (w/o PSU) £159.95 £187.94
250GB SATA Samsung SP HDD
LN8448 Microsoft Windows XP Media Center 2005 Edition Software *OEM*
Help would be most gratefully accepted!
