Silver Crest SL65 - beginner's question
Discussion in 'Satellite TV, Sky TV & FreeSat' started by organica, Sep 17, 2005.
  1. organica
    organica
    Hi all -
    embarrassingly rudimentary question for you...
    My dad just got a silver crest SL65 from LiDL, planning to use it as a freeview box.
    I have no experience with satellite, but looking at it, it seems like it needs a dish to do anything at all.
    Is there any way to attach the SL65 to an aerial and use it as a straightforward terrestrial freeview box (signal reception is very good where he lives).
    Thanks for yr indulgence :D
    gordon k
  2. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +309
    A satellite receiver has to be connected to an LNB on a suitably aligned dish. If you connect it to an aerial you'll short-circuit the internal LNB voltage supply. It certainly can't be used to receive terrestrial Freeview signals.
  3. organica
    organica
    Thanks Sam -
    I reckoned if it was possible, they'd have stuck on a coax socket - but that confirms it. Cheers.
