Silly question
S
s9s
I know it is! Here goes, my gf has ntl in here area but in her flat she has not analogue feed through the roof areial (wall socket), she has a areial plugged in the back of the tv, is it possible for her to get a free to view box or otherwise and watch digital tv? As u can see i am really ropey onthis subject.
Thanks in advance.
If I understood your post correctly, your girlfriend doesn't have an external aerial. If so, she could try using an DTTV free-to-view box with an indoor aerial like this one from Argos:
http://www.argos.co.uk/webapp/comme...enbr=6970&type=big&thisMode=ols&cgrfnbr=74874
I've never used one, but it claims to be compatible with digital TV so if it doesn't work, then I guess you could take it back to Argos for a refund.
It is a good idea to also check your girlfriend's postcode to see what the digital reception is predicted to be. You can do this online at: http://www.dtg.org.uk/retailer/coverage.html
Ta very much squirral god, will give it a try in the near future and let you know if it works.
s9s
I have a free to view box and recently tried moving the box from it's normal downstairs location with external aerial feed.
I have very good reception both analogue and digital.
At the new location the DTT box was connected to a portable and I used the normal portable loop aerial as the feed source.
The picture was perfect, no break-up at all. If you are able to receive DTT signals at your location (try the postcode check as suggested) then the quality of your analogue signal might give you a rough indication of potential success.
I have very good reception, so I think that made the use of the loop aerial viable for me.
Good Luck :)
regards
cow
The general analogue reception is poor, so i may get her an areial as suggested by SG or some other amplified but i will try with the loop areialk first, i soehow never though it would be possible but now i know it is. Thnaks
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
