Silly Question?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Shin Gouki, Jan 14, 2004.
  1. Shin Gouki
    Shin Gouki
    :blush:
    Is the viewfinder the LCD screen? :confused:
    Ive noticed that some camcorders have either a blcak & white or colour viewfinder. You can't tell me that some camcorders still have black and white LCD screens. :thumbsdow
  2. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    The viewfinder is the small window you look through when you hold the camcorder up to your eye and is different to the LCD screen which you view by holding the camera away from you.
    A lot of the lower end camcorders, whilst using a colour LCD, only use a black and white viewfinder. This helps to keep the prices low as colour viewfinders are more expensive to make than black and white ones.
    I'm not aware of any camcorders that use a black and white LCD screen, although I suppose there might be a really dirt cheap one out there somewhere which does.
    Hope this helps.
  3. Shin Gouki
    Shin Gouki
    I told you it was a silly question. :blush: :laugh:
    Cheers mate. :smashin:
