Silly question with a probably simple answer
Discussion in 'Desktop & Laptop Computers Forum' started by Shoka, May 28, 2003.
  1. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    On my laptop ive got a video out, this is a socket in which I can plug a phono Jack (like headphones) the end of this wire teerminates in a yellow Phono.
    My question is how does it work, Im thinking If I plug it in it will bring the laptop screen onto the TV, but it doesnt, do I need to change a setting somewhere.
    This isnt for watching movies or anything I just thought it would be fun having a huge screen for my laptop.
  2. graham.myers
    graham.myers
    Mar 11, 2003
    6,230
    Leeds
    +931
    its a composite out same as on a dvd player. so either plug it straight into the yello phono on yer telly, or into a scart converter
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,258
    Manchester
    +753
    It should explain this (albeit briefly) in your laptop manual.
    On my Dell Latitude I know it warns that you need Win2000 or WinXP for this to work (not WIn98SE or earlier) .
    Chris Muriel, Manchester.
  4. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    tried that doesnt work.
    I have XP and the laptop is a sony vaio. Not explianed at all in the manual, apart from the fact it is a video out port.
    Any other ideas?
  5. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Does it need to be enabled in the right click>display properties>advanced bit?? might be a tab that enables it.??:confused:
  6. BBD
    BBD
    Mar 13, 2001
    442
    Lutterworth
    +3
    I haven't got a Sony but from experience with a few other video cards/ Laptops with TV outputs (mainly ATI)
    Have you checked that it is enabled?
    Right click on the Desktop>properties>settings>advanced
    Next bit depends on the driver but probably 'Monitors'
    You may not be able to enable the TV option if
    1) You are not currently connected to the TV
    2) Your screen res. is set too high, start with the lowest res available and work your way up.
    Hope this helps
    Dennis
  7. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    thanks loafer got it working but the PQ is crap cant even read the screen, is there anything I need to change?
  8. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The crappy picture is normal, the only thing you can do is lower the res to 800x600 or even 640x480. Also check that it is outputting PAL rather than NTSC, the extra resolution should help.
    Jeff
