Silly question but ......
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by rupertx, Dec 13, 2003.
  1. rupertx
    rupertx
    Apr 21, 2003
    317
    Dunblane, Scotland UK
    +8
    How do you erase dv tapes or do you simply record over the top of the previous recording?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I don't! :nono:
    I don't see the point in reuseing a DV tape when they can now be bought for around £3 each. Say you record something you want to keep, copy it to DVD-R or even VHS and wipe the DV tape. If you then loose the recording or it breaks/gets damaged you then have no option to recover it. I still have the origional DV tapes for everything I have filmed.
    But if I did ever need to reuse a tape I would bring it into work and use a machine that we have for erasing data from old tapes. This passes a strong magnet over the tape and wipes anything recorded. Any strong magnet will do this like a TV or speaker.
    You could just record over the old recording, but this often does not completely wipe it and you might be able to see the old recording as ghosting. This all depends on how good the heads on the cam are and the quality & age of the DV tape.
    Mark.
  3. Arthur.S
    Arthur.S
    I've got some Panny DV tapes that I've reused 5 or 6 times with no problems at all. I only keep my 'master' tapes. (Completed project)
  4. Origin
    Origin
    Errr, stick the lens cap on, put the camera in a quiet room, press record and come back an hour later?
