Silly Question - Backing Up DVDs
Discussion in 'Desktop & Laptop Computers Forum' started by ap69, Aug 26, 2005.
  1. ap69
    ap69
    Jan 28, 2005
    429
    +15
    Am sure this is a no-brainer for most of you clever folks, but what software could/should I use for backing up my commerical DVDs onto my PC's hard drive?
    Eventually I'd like to play these through my plasma screen, but I like the thought of putting all my DVD content in one place (and possibly enhancing output quality).
    Many thanks
  2. inzaman
    inzaman
    Dec 16, 2002
    7,874
    Derby
    +927
    I use DVDshrink which is excellent imo, you can also rip them to the hd without shrinking the files. It also allows you to reauthor the dvd so you can cut the credits out etc and save on space.
  3. lisag
    lisag
    Jul 14, 2004
    5,556
    Essex
    +296
    DVD Decrypter is my favourite - although the guy who wrote it has been closed down by the authority's but there may still be some copies of the software floating around on the net.
    lisa
  4. ap69
    ap69
    Jan 28, 2005
    429
    +15
    Inzaman/Lisa - thanks for the info, much appreciated.
    Just a few more questions:
    Do your choices offer any sort of enhancement to picture quality?
    Is the copy protection an issue (note: this is strictly for my purchased DVDs, before anyone complains!)
    What about Divx/Xvid - do these allow DVD backup?
  5. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    I use DVD Xcopy, the old version that allows a backup removing the CSS copy protection, just 2 mouse clicks and it's done, might have trouble finding an old copy though.
  6. lisag
    lisag
    Jul 14, 2004
    5,556
    Essex
    +296
    I think enhancing pq on DVD's will depend on how you play them back, a mixture of hardware and software configuration.
    Divx/Xvid are codecs that enable you to compress the files to a smaller size, you always lose some quality in doing this, how much depends a lot on which codec, which form of compression, how much compression and how you view them afterwards.
    lisa
  7. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    there was a thread on avsforum about ripping your DVDs and using software to process the picture prior to saving but this was pretty convoluted as I remember. not sure it would give enough of a benefit over just using a good software/hardware combination (like Theatertek 2 dvd player and an nvidia 6600GT card) to be worth it.
    if you're interested you could do a search on www.avsforum.com and look for it, IIRC it had "avisynth" in the title.
    HTH
    owain
  8. inzaman
    inzaman
    Dec 16, 2002
    7,874
    Derby
    +927
    I'd have thought (this is a guess though) that this would be more troublesome because if you do not like the enhancements you will have to re-rip the movie to the hd. I'd also imagine that this would take considerable time, i personally rip them as they are then use ffdshow to post process. Mine too are all my own movies as i am in the process of building some form of movie juke box.
  9. Fast Jon
    Fast Jon
    Dec 8, 2004
    260
    +10
    I am definitely a non-techie, but I have backed up my DVD collection (including quite a few R1 discs) using DVD Decrypter and DVD Shrink. Both are freeware and easy to use. My backups are region-free and the originals now live in a drawer where they won't get damaged.
    You only need to shrink if you are backing up dual layer originals to single layer +R or -R. You can also use DVD Shrink to chop out unwanted content such as theatrical trailers and foreign soundtracks.
