Silly question about the PSP
azzo
This may seem obvious , but is there a pause or standby button,
so for instance you could watch a movie, or play a game and at any point
switch the machine into a power save mode and resume when you can.
azzo
Baron Von Doom
there is a pause button for films. or you can just push the power switch to turn into standby mode. when turned back on game will be where you left it.
azzo
** Clap hands **
Does pushing the power switch work for movies too. i.e. resume when you switch back on.
azzo
chrislad
For UMD movies, I don't know, but I know if you go to standby, the film does turn off but if you select the same file again, it should pick up where you left off.
figoagogo
azzo said:
** Clap hands **
azzo
YES - I think. The sleep mode will put the PSP to sleep and will resume at the same place, be it a movie, game or www :D
Its an excellent function, but uses up power
Moogrose
Actually, reviews on IGN put the sleep mode function in as using hardly any battery at all.
figoagogo
agreed, but it does use a little extra... :D
drskhaled
sleep modes works with most games (wipeout has issues) and with umds it resumes play though not as instantaneous as with a game (probably searching for the point on the disc).
h0l1yw0od
The Start button also pauses games, like on a console control pad.
