suniil
Hi all,
I'm trying to figure out fixing my pw7 on wall with RS100 mount. Where should be the vertical bars to be mounted on the back panel.
I can see the following
a. On both side edges on backside 4 threaded holes - I assume these are for speaker attachment
b. There are 4 big black screws fixed on the backplate
c. Another series (vertical) of holes in both sides without threads
Can anybody confirm which one i use?
Also i've not received any screws for fixing this with plasma panel. Any ideas?
Thanks in advance
N2P
Thanks in advance
N2P
