SilentGliss Electrically Operated Track & Infra Red
Discussion in 'Home Cinema Control & Remote Controls' started by chirpychips, Dec 31, 2003.
  1. chirpychips
    chirpychips
    Jan 18, 2003
    30
    11
    London
    Does anyone know whether an IR Distribution Amp output can be wired directly to the back of SilentGliss' motorised curtain control unit? I notice from their instruction sheet that their own IR receiver connects to the back of the control unit using some kind of "sensor plug" - rather than loose wire connections. If it's possible I would rather do this than stick an IR emitter onto the SilentGliss IR receiver. In any case their sensor looks quite ugly!! Can't seem to get an answer from SilentGliss....
    Chirpychips
