Silent Plasma?
Discussion in 'Plasma TVs' started by RossC, May 29, 2003.
  1. RossC
    RossC
    Feb 13, 2003
    144
    Reason for asking is my new Toshiba 42PW27 isn't. And silent operation was one of the reasons for choosing this display...
    Basically it is making a buzzing/busy-cricket chirping type noise, that comes and goes and seems to change with the screen intensity. The screen is firmly wall mounted (solid brick) and the noise can be heard over normal level TV (say the news for instance) and is driving us spare. Have taken the unit back and swapped it out to try another, but....ss this normal?
    Considered the Hitachi 400 (fans) and the Pioneer MXE (not such good blacks) before choosing the Toshiba.
  2. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    My Panny is a noisy bugger too. It's not audible over normal TV and doesn't interfere with my enjoyment of movies. I thought they'd be silent too :(
    D.
  3. LeonidS
    LeonidS
    Feb 11, 2002
    63
    you can find a lot of information about plasma noise in this forum - just search ... but summary - most of them are not silent at all.
    Pioneer seems to be the best in this respect... that's why I have chosen it ... but still waiting for it.
    some people are using acoustic foam or just towel to decrease the noise level ( just install it behind the screen ) ... but this is not so easy to do if screen is wall mounted ( I guess ) ... but maybe something could be done.
  4. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    PIO 433MXE silent as the grave so far !!
  5. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    PIO433MXE has 2 fans on the back.
    there only auto enabled by the S/w when the thing gets hot.
    Mine like other users here has never come on.
    The temp Guage in the menus is always at its lowest (cool)
    even after hours of constant use.
    So no sound whatsover.
    I hope it supposed to behave this way ????
  6. DEO
    DEO
    Hey Leonids
    Where did you order from, is it 433 or 503MXE
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    RossC
    Your Toshiba display is based upon the current Panasonic PWD5 chassis and whilst this chassis has no cooling fans it does tend to produce an audible hum when generating an all or near all white image - the level of noise can vary slightly between individual displays but they basically all exhibit some hum.
    Deo
    Both the PDP-433MXE and PDP-503MXE have two cooling fans and as Tony points out they are temperature controlled via the screens software menu and the 'normal' setting combined with a 'normal' room operating temperature will happily keep the fans switched off.
    The Pioneer PDP-433HDE and PDP-503HDE PlasmaTV models dont have fans - though the Media Box does get pretty hot.
    If you want a 'silent' Plasma Display or Plasma TV go Pioneer - I sometimes feel like some mad evangelist going on about fan noise and mechanical hum but I've learned over the years that many customers are very intolerant of any mechanical noise produced by kit that they have to live with.
    Best regards
    Joe
  8. LeonidS
    LeonidS
    Feb 11, 2002
    63
    I have ordered it from EmpireDirect during discount weekend - could not resist the price :) ... but still waiting :(
  9. RedRose
    RedRose
    Jan 30, 2002
    108
    Preston, Lancs
    I bought a 50" Panasonic last November but the sound of the fans and the PSU buzzing drove me to distraction. I really can't get inside the head of anybody who is willing to pay £5K+ for something which will be the focal point of their living room and then make up excuses for the din that it makes. It may be that I'm just intolerant, but if we put up with low standards of quality then why should the manufacturers bother to improve their products?
    Anyhoo, I voted with my feet and swapped it for a 503MXE. Completely silent, the fans have never ever come on. Its a superb piece of kit and I recommend it to anybody. I'd say that the PQ of the Panasonic is 5% better-whatever that means to you- but the silence is worth it.
    If we all had the same criteria and budget then I guess we'd all have bought the same product.
  10. nhk
    nhk
    Dec 30, 2002
    82
    This subject caused me quite some delay before placing my order for a plasma. It seems there are so many varying opinions.
    I was very concerned that the 50" Panny with its "constantly on" fans would make viewing at night unpleasant. However, I took the advice from some more experienced people on the forum and went for the Panny over the Pioneer on the picture quality.
    In hindsight (or perhaps I am just lucky), I am very satisfied and can hardly hear the fan of the 50". I previously had a 42" Panny on loan and the power supply buzzing was audible (especially when the unit displayed bright images).
    The 50" has virtually no buzzing and I must say a very quiet fan. I can definitely hear it on start-up (a slight whoosh) and then it settles to inaudibility. It does give me some comfort to know that the unit is being cooled down though.
    Regards
  11. rwmcjazz
    rwmcjazz
    Feb 29, 2012
    the Panny's fans will start making more noise as they collect dust and dirt from the air in the room. Blow the fans clean with a compressed air can while holding a vaccum brush against fan cover area as you use the compressed air. Otherwise, you'll have to remove the back panel, and that will be a major pain in the a%^$#s.
  12. BJQ1972
    BJQ1972
    Jul 2, 2010
    1,029
    Teesside
    +302
    I'm not sure they will still be having the problem.
  13. Ricky27
    Ricky27
    Feb 8, 2002
    1,866
    Norwich
    +204
    lol probably had 5 new tvs since 2003 but still, advice is always appreciated
  14. mancs
    mancs
    Feb 5, 2012
    804
    46
    +169
    why does my panny th-42pw4 not make a noise? its like 10 years old and not only is it silent it still looks great *smug grin*
  15. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    Your hearing must be shot - it’s an aging thing; gets us all :devil:
    Joe
  16. mancs
    mancs
    Feb 5, 2012
    804
    46
    +169
    :rotfl:
