Signal Strength
Discussion in 'Satellite TV, Sky TV & FreeSat' started by johndj1, Aug 27, 2003.
  1. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    I've been experiencing Technical Fault with this Channel and No Satellite Signal being Recieved messages for the last couple of weeks which intermittently seems to be on the high band channels (Sky One, MTV etc) whilst the traditionally crap channels (BBC, ITV) are fine.
    I've done some research through the forums already and concensus seems to be the following. It is either:
    1. Poor dish alignment
    2. LNB Skewage
    3. Dodgy Cables
    4. Dodgy STB
    I've checked the signal and it looks fine (about 70% for strength and 60% for quality). However, these are greyed out?? Additionally the cable comes pretty much straight into the house from the dish and runs under the floorboards to the STB. It hasn't rained for weeks anyway.
    Armed with this info it would be great if someone could let me know whether I can get up a ladder this weekend to sort it out, or whether the STB (pace) looks like the culprit?
    Any response welcomed.
    Dan
  2. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Apologies for the additional message but am keen to know the answer to my question on error msgs coming up on my TV.
    At the moment I have a "No Satellite Signal Being Received" and "Technical Problem" on the majority of channels (although BBC1, 2 and ITV are fine.
    The signal strength and quality are 70% and 60% respectively but appear in grey (is this right?)
    If this is fine then I am assuming it is the box, but before I pay the £65 it would be great if someone could confirm my suspicions. Or do you think I could resolve it by fiddling with the LNB and/or dish.
    If you could let me know asap that would be great.
    Sorry to hassle
    Dan
  3. Robbie34
    Robbie34
    Jul 6, 2003
    331
    Merseyside
    +11
    Do you have a Panasonic box, because this, apparently, is a common fault?
  4. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Nope, it's a Pace. Although I did used to have this problem with a previous Grundig box.
    If anyone can confirm that my suspicions around the box are justified then I'll just get the Sky man in. Do the signal strength and quality sound okay?
  5. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Signal levels seem fine although I am not sure what you mean by grey, are you just referring to the colour of the bars against the dark blue background? If so then that's normal:)
    Since you are receving some channels then the system is showing a lock on the satellite?
    Network ID..............0002
    Transport Stream....07d4
    This still points to a problem with high/low band switching which is either the LNB, cable or the digibox.
    Always worth the effort to take your digibox to a friends house and try it on their dish to see if the problem follows the box or stays with your dish/lnb setup.
  6. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Thanks Starburst.
    Almost gonna do that in that I'm going to borrow an STB from work and try it at home this weekend.
    I'll let you know what occurs
    Dan
