signal strength/
Discussion in 'Desktop & Laptop Computers Forum' started by DustySox, Aug 22, 2005.
  1. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    I am using a D-link G604t wireless router. It runs quite happily my desktop and laptop, however with the laptop I have noticed that those little annoying pop ups that tell you speed signal strength etc shows that signal strenghth is always good to very good, unlike the speed which seems to be all over the place.It can as low as 1Mbps and sometimes 11Mbps. How would I "up" the speed as it can take an "age" to open web pages even on a broadband connection?
    ATB
    Darren
  2. The Dude
    The Dude
    May 21, 2004
    6,283
    Beverley, East Yorkshire
    +2,601
    it auto-negotiates the connection speed based on the signal quality....
    screwing one of these on the back should sort things out.. ;)
  3. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Hi Dude,
    Do you mean screw this into the wireless router?
    ATB
    Darren
  4. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
  5. The Dude
    The Dude
    May 21, 2004
    6,283
    +2,601
    yeah, it will go straight on there... you should see a signal improvement of 100% or more, the 2db antenna supplied with WAP/Routers are amazingly bad at what they do...
    the actual problem is partly with the reception on your laptop, but boosting the output from the router is the best/cheapest solution.. :smashin:
  6. The Dude
    The Dude
    May 21, 2004
    6,283
    +2,601
    hahahh - I was pretty sure the antenna is detachable on your 604...? if it does, you'll be fine.. Solwise must have an out of date spec, it will definitely have the RevSMA connector if it screws off.... :smashin:
