signal strength
Discussion in 'Satellite TV, Sky TV & FreeSat' started by spocktra, Dec 1, 2004.
  1. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Can anything simple be done to improve signal srength and quality.I have what seems like 60% on both.
  2. matty2767
    matty2767
    sky or FV?
  3. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Sky quite an old amstrad box.
  4. matty2767
    matty2767
    carnt help you then mate - sorry
  5. bignairy
    bignairy
    Mar 13, 2004
    96
    Why do you want to? The whole point of Digital TV is that once you have sufficient signal to receive the bytes, the picture quality is as good as it will ever get.
    Unless you are seeing drop-out, then just enjoy it and stop worrying!
  6. cyber
    cyber
    had same problem try putting the signal through a booster. As one previous said if the picture is OK the only thing improved rates would do it stop any blocking
  7. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    New dish, new LNB, new cable, new digibox.
    Realigning existing dish, re-positioning existing LNB.
    All of those options could improve signal reception, while digital is an on/off system it can be improved by using less error correction to fill in the gaps before reaching the threshold when the reception goes.
    No experienced it myself but many people have said that the picture quality has improved by tweaking the dish alignment etc. However as bignairy says you may be getting a good picture with the current hardware and increasing the signal levels 10% or so won't make any appreciable difference. The digibox meters are not exactly accurate, they should only be used as a guide.
