Signal strength/signal quality
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Len, Aug 21, 2002.
  1. Len
    Len
    In the set up menu when I do the signal test... the strength of the signal is 100% But the quality is about 60%.
    Any info on this.... and how can I improve quality?
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,915
    71
    50 Rue St Georges, Paris.
    +32
    That's a very good set of figures, probably the best you'll achieve.
  3. KevB_UK
    KevB_UK
    Yes those are very good, but you need not worry about the figures, if you get a picture in the rain then the dish is aligned ok.
