Signal Strength Boost
Discussion in 'Satellite TV, Sky TV & FreeSat' started by stevebez, Aug 9, 2004.
  1. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    Is it possible by means of an amplifier to boost the signal strength?
    The signal quality I am getting is pretty good at >80% for both feeds, but signal strength runs at around 50-55% and I get some break up occasionally.
    Any remedies to suggest?
    Rgsd Steve.
  2. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    Don't think so - check dish alignment > upgrade LNB > get bigger dish, in that order.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,496
    South Derbyshire
    +203
    Signal boosting not possible other than what Ivan points out.
    Get bigger dish.
  4. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    Thanks its an apartment block complex, so I guess would need them to check the dish, and I assume it would be one of a substantial size / lnb setup.
    They recently just upgraded the down the line equipment so it should provide better strength than this.
    I'll buzz them and see.
    Thx guys. Steve.
