Signal problems with new TV when Sky remote settings on RGB.
Discussion in 'Sky Digital TV Forum' started by chipset, Feb 25, 2014.
  1. chipset
    chipset
    Apr 25, 2012
    24
    Got Freesat from Sky with an old Panasonic box and a new Samsung TV - connected via scart. Everything was great on set up apart from pixelation and break up on Sky news. Which was odd as the one channel I could get even in bad weather was Sky!
    However when tinkering with the Sky remote settings, I discovered that by switching the picture format from RGB (which I used with the old CRT) to PAL the problem was sorted.
    I don't understand. Does this mean the new TV is formatted just to work with PAL? [​IMG]
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
  3. winston2010
    winston2010
    Jun 28, 2010
    1,895
    London
    +191
    As you also posted this on digitalspy I suggest you read the answers you got there.
