Quantcast
Signal problem
cwood1
I there, I recently bought a second tv formula extension. My main tv is approx 20ft from where the new tv is. I have connected both tvs with an aerial cord that is joined at a midpoint. The main tv is absolutely fine however Ian unable to get a signal on the other tv. Occasionally I get intermittent flashes of a picture. Can someone advise me on how to fix this problem?
bow79
Probabley best way to split an areal signal would be arial in to areial amp box with 2 outputs. Have you just used a triangle shaped thing with arel conectors? I have in passed and it has been ok. If you have a freeview box or equivalant, use that. Arial in scart conection to tv1 areal out to tv2.
