bogart99
Hope this is the correct forum to post this topic.
My setup is a sat signal and a terrestrial signal combined then fed down a single downlead to near to the tv. The signal is then split, one leg going to the tv (digital tuner) the other via 10m of coax to a screened diplexed wall outlet. Only the sat signal is used the tv outlet at the diplexer having no connection. The signal to the tv is fine no break ups when the sat equipment is switched off. If powered up the tv signal degrades to the point that certain channels report no signal.
I find this odd as the tv signal is not being utilsed at the end of the 10m run, if another set was connected and switched on I could understand it occuring in that situation. I wondered if, haven't tried yet, I should replace the splitter near the tv with a decombiner and see if that helps. It doesnt seem to worry the tv that its getting a sat signal as well or is it?
Regards
Regards
