signal conversion question
Discussion in 'Blu-ray & DVD Players & Recorders' started by dingo8yobaby, Jan 18, 2005.
  1. dingo8yobaby
    dingo8yobaby
    Jan 29, 2004
    2,021
    83
    a place that haz no reconz:(
    +294
    if my tv only has s-video input, is it at all possible to find a dvd recorder which can take an rgb signal from sky via scart and output it via s-video to the telly-ie convert rgb to s-video? please help if possible, cheers. :thumbsup:
  2. mambojambo
    mambojambo
    Dec 23, 2004
    141
    +3
    you need THIS m8 :smashin:
  3. dingo8yobaby
    dingo8yobaby
    Jan 29, 2004
    2,021
    83
    +294
    thanks- its almost as if they made it for me personally! :D
  4. joegib
    joegib
    Jul 13, 2003
    77
    London, UK
    +10
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,224
    Warwick
    +2,268
    Just to answer the original question then, yes, some DVD recorders will do this - Panasonic for example. Generally the conversion is quite good although a JS converter is obviously going to do it somewhat better ;)
