Signal Booster to allow Freeview
Discussion in 'Freeview & YouView' started by GlennP, Nov 22, 2004.
  1. GlennP
    GlennP
    I have a second TV hooked up to a loft aerial - manages to pick up some Freeview channels but not all. Will a signal booster enable me to pick up the missing channels or do I need a beter aerial.
  2. Johndm
    Johndm
    Jan 25, 2003
    1,809
    Bedford UK
    +56
    I was here last christmas......you need a better aerial, it will save you huge amounts of grief!
  3. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    629
    A signal booster worked for me. It's a gamble I guess, but may show that you don't actually need to upgrade your aerial. Maybe you know somebody you could borrow one off first to check?
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    In a lot of areas you need a wideband aerial for Freeview, and yours may only be usable over part of the band and may not pick up all the muxes.
  5. MJ Invincible
    MJ Invincible
    Glenn, you could get a signal booster from Argos/Index and return it if it doesn't work. Although you may find that you require a better aerial.
  6. Garrett
    Garrett
    Apr 21, 2001
    32,949
    2
    167
    The best thief you’ll never see.
    +4,339
    There is two types of booster one for boosting signals down long lengths of cable where loss is likely to occur.
    There is also a mast signal booster which you place as neat to the aerial as possible to boost weak signals.
