Signal booster makes picture worse!
Discussion in 'Cables & Switches' started by nal, Jul 24, 2004.
  1. nal
    nal
    May 24, 2003
    All my tv's have freeview boxes connected and are fed from an antiference 3 room booster. Just happened to turn to ordinary telly on a bedroom tv and the picture has fine lines thru' it, same on all the other telly's. If I connect the tv directly to the aerial the picture is fine but if I put it thru the booster it's not. I have a 4 way low loss passive splitter which works ok, but this will mean I'm losing signal. The living room tv is not connected to the booster hence it hasn't been noticed sooner. There is no masthead amp as I get a good signal and the downlead is ct125. Have also tried another booster with the same results.
    Anybody know what's happening?
    tia,
    nal
